Engine won't start - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2009, 04:26 PM
Engine won't start
Help. I have just rebuilt a SBC and put into a Nova for a friend of mine. The engine will not fire at all. I have checked the wiring, timing setup, coil resistance, voltage to coil off and during cranking. I have spark at the plugs but the engine does not even try to fire. In many years of doing this I have never had this problem. The only thing I can find out of ordinary is that the guy has a Crane XR-i module in the distributor. This was in there before and the engine ran fine. However, in tracing the wiring I discovered that he did not have a resistor in the wiring as the crane instructions say. The coil is not a coil with internal resistance as it only has 1.3 ohms. Could this have caused the module to be damaged?
Any help is appreciated. Thank you
Old 01-01-2009, 05:33 PM
DoubleVision's Avatar
If you got spark it should fire. Pull a plug and see if you smell fuel on it. if you don`t, give it more gas, pump the carb at least 5 times and be assured the acc. pump is giving it a good pump shot.
Old 01-01-2009, 05:42 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Yeah if you have spark at the plugs you should get something..
Might sound stupid but make sure you have good fresh gas. Also a shot of starting fluid should get you fire.. If it don't then you can rule out spark and fuel.
Old 01-01-2009, 06:20 PM
Jmark's Avatar
If spark is good and you have fuel at the plugs, run a quick compression test on one or two cylinders. Over tight valves will give you fits as will an improperly set up timing chain/gears.
Is the dist firing at number one? Have you cold timed it to verify fire at #1? Just tossing out the basics when things don't made sense.
Mark
T-bucket23's Avatar
Wiki Edits: 26
90% of teh time its timing. Check it again.
Chet
Old 01-01-2009, 08:52 PM
Thanks for the replies. Yes, I do have fuel at the plugs and have even dried them off because they were flooded. I have verified the timing by checking the timing mark on the balancer and the closing of the valves on #1 cylinder. I did a compression check and all cylinders showed within a pound or two of the same compression, 95psi. This is on a cold engine with no running yet. Still no attempt to even fire. I put new gas in the cell, but there was probably still some gas in there that was 3 or 4 months old.
Thanks again.
Old 01-01-2009, 09:35 PM
Jmark's Avatar
With only 95 pounds of compression, i'd be wondering what went wrong. It would be hard to fire with that low of a reading.
Old 01-01-2009, 10:02 PM
Does it seem like the timing is right? No unusual stuff going on like blowing back out the carb? Not 180* out? Valve adjustments all good? Im guessing it must be electrical or a timing issue. Could be a distributor issue as well.
Old 01-01-2009, 10:07 PM
If you happen to have spares you might try a different distributor cap and/or rotor. Go over the little stuff with a fine tooth come before you dig deeper. Chances are something will make it fire.
Old 01-01-2009, 10:25 PM
Greg T's Avatar
www.krusinklassics.net
Cam timing is off by a couple of teeth.
Old 01-01-2009, 10:57 PM
406 bug's Avatar
9.82 @ 139mph
Put your timing light on 1 , turn it by hand , when lit, see where your timing mark is and check you valves to make sure they are closed. I think you will find your prob.
Old 03-12-2009, 08:20 PM
hope im not being rude by jumping in your thread here but i was just searching through posts to find out why my 350 spits gas out of the carb and does not fire up. i have already adjusted valves (2x) and double checked my firing order (countless times) i have been sticking an allen wrench in #1 till it wiggles the least amount and my mark is about where it should be then drop my hei in pointing at #1. this usually works for me and the car was running fine before. timing chain? i also heard a clunk the first time i tried to start it and now it wants to act like the batt is dead when i try to start even though i have 12 volts. can it jump timing? (roller chain 1 month old). motor is mostly stock 1979 350 in a chevy caprice
Old 03-12-2009, 08:24 PM
how does that work? the light still flashes when you turn it by hand?
setting points on sb chevy frackster66 Electrical 23 01-07-2014 06:50 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 11:12 AM
Oldsmobile 3.8 engine won't start oldchevy1956 Engine 5 06-05-2008 06:58 AM
Engine Start Up sjohn Engine 16 05-18-2006 11:18 PM
Help! engine won't start Jeep'n Engine 9 11-13-2003 09:39 AM
