engine wont start? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2011, 01:11 AM
engine wont start?
have a 63 imapala ss, 327 small block. replace intake manifold, carb, spark plugs, wires, and fuel pump. set timing to TDC no. 1 cylinder and set carb to specs for fuel/air delivery. engine will crank but will not start, have spark, and fuel. carbs spits fuel out of air cleaner when starting. what is missing to get engine to start? oil smells like fuel too.
Old 01-14-2011, 03:04 AM
DoubleVision's Avatar
First off, fuel gets in the oil 2 ways. Either a piston has a hole in it or the fuel pump is ruptured. Gotta fix it, fuel in the oil will quickly destroy the engine.
If it`s spitting back out of the carb it`s not timed correctly. When timing it did you remove the number 1 plug and make sure it was on the compression stroke?
Here`s how I set timing. I drop in the distributor, don`t care where. Bump it over until it drops. Remove the number 1 spark plug. Have a buddy bump it over until the distributor rotor is almost pointing to number 1. Yank the distributor. Bump it over again until it`s on it`s compression stroke top dead center. Reinstall distributor, it should fully seat pointing at number 1. The reason for installing and yanking the distributor and getting it almost pointed at number 1 was to assure it was fully seated in the oil pump drive. Snug the distributor, replace the cap, break out the timing light, fire it up and time it.
While your at it, check it for vacuum leaks.
Old 01-14-2011, 10:52 AM
ericnova72's Avatar
More for Less Racer
Sounds like you are 180 off on the distributor, it has to be TDC firing plug and not TDC exhaust stroke. 4 stroke engine, remember, TDC comes around twice but is only firing once.
Old 01-14-2011, 11:29 AM
poncho62's Avatar
Wiki Edits: 5
Yes....the spitting back of fuel is the clue.....a lot of times it will shoot flames back up through carb too
Old 01-14-2011, 03:08 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I also agree it's 180 out.
Cole
Holley 650 on 350 chev wont start once engine is hot, help gilflite350 Engine 17 11-09-2010 05:12 PM
Holley 650 on 350 chev wont start once engine is hot, help gilflite350 Hotrodding Basics 3 11-08-2010 11:43 AM
engine wont start protrabbi Engine 13 10-06-2007 04:37 AM
engine wont start johnnyfast Engine 5 03-30-2006 12:02 PM
Engine wont start anymore grandprix601 Engine 13 04-12-2004 11:25 PM
