Engine wont start - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2012, 09:50 AM
K72Nova's Avatar
Engine wont start
Pulled my HEI to do a little work and now I have it back on but I forgot to mark it so I had to go back through and find TDC, set the distributor in and now I can’t get it to start. I have some pretty nice 1'-2' flames coming out the headers but the backfires aren’t very loud, either way I am definitely getting fuel and spark. The engine ran fine before I pulled the distributor but now it's not even making a small sputter like it’s trying to start or anything. Anyone have an idea what could be my problem? I have heard a lot of being 180 degrees off but what exactly does that mean, if that is my problem anyway.
Old 03-26-2012, 10:27 AM
Richiehd's Avatar
JS-70
Sounds like thats what youve got. Distributer turns half speed of crankshaft, so you are 180 out. Set dist. to #1 fire on COMPRESSION stroke. Pull #1 plug out and have a buddy bump it over as you put your finger over the hole. As piston comes up you will feel a pop as compression builds. Then turn slowly and as the mark comes to the line, thats # 1 compression, thats where you want the rotor to be positoned on the cap, at that terminal in the distributer.
engine cranks but wont start novadan Engine 5 11-18-2011 10:11 PM
engine wont start? impalas6364 Engine 4 01-14-2011 03:08 PM
engine wont start protrabbi Engine 13 10-06-2007 04:37 AM
engine wont start johnnyfast Engine 5 03-30-2006 12:02 PM
Engine wont start anymore grandprix601 Engine 13 04-12-2004 11:25 PM
