Engines you'd like magazines to build - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2008, 06:18 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
These I think would be some neat builds, a change from the normal sbc. If you want them to build a sbc, then say why it's different from the usual ones, be it budget build, or a miracle combo that makes 480hp off a gen1 based 383 for $4000.
4.3L (262ci) Chevrolet v6
4.0 (242ci) Jeep i6 (use a AMC 258 crank for more displacement)
Buick Nailhead v8
Pontiac straight 8
Mopar slant 6
Ford inline six
Chevrolet stovebolt
AMC 327 v8
Old 09-25-2008, 08:15 PM
4 by 4 magazine did an article on hoppin' up those jeep 6 cylinders it was pretty neat. oh you forgot one, the early chrysler hemis.
Old 09-25-2008, 09:02 PM
Twin Turbo 6.5 Diesel
Shane
Old 09-25-2008, 11:13 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
Ford flathead or even the later Y-blocks would be different than the typical builds you see.
Old 09-25-2008, 11:18 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
How about a turbocharged Oldsmobile 215 V8...
Old 09-25-2008, 11:55 PM
powerrodsmike's Avatar
Wiki Edits: 161
You did not specify anything other than "engine"
So,
How about....
A radial airplane engine ..
Truly a thing of beauty.
The innerds are way cool, the technology is no different than a pushrod car motor, but the way they got all that stuff to work in a circle took the kind of design work that few can imagine.
they got hotrodded too.
If you want more power, just bolt 1 or 2 or 4 7 cylinder radial motors together.
Pratt & Whitney "corncob" motor...4360 cubic inches.
Found that stuff here...http://fastjeff57.tripod.com/
There is one like that that is over 7700 cubic inches.
If you want to see some really bizzare ways to convert fossil fuel into rotary motion, check that site out...scroll all th eway down for something like you've never seen.....a supertanker diesel.
Yeah I'd like to see the magazines do a build of one of those...
Later, mikey
BE different....ACT normal.
Old 09-26-2008, 05:56 AM
Blazin72's Avatar
Wiki Edits: 19
Great site Mikey.
Old 09-26-2008, 02:38 PM
72 grabber 51F-1 65 chevystang
old flatheads or straight 6's. basically anything but a sbc
Old 09-26-2008, 03:01 PM
Irelands child's Avatar
Later, mikey
Thanks Mikey - I had lost that link when I changed computers in Jan. Now I can finish reading about some strange engines.
Dave W
Irelands child
Old 09-30-2008, 01:35 AM
Wiki Edits: 7
someone in the 'exotic engine' thread mentioned a Hudson inline six.
Old 09-30-2008, 06:44 AM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
I second the early Hemi's and add a 4.6 all aluminum Ford DOHC modular...
Old 09-30-2008, 10:50 AM
High RPM chevy small block on pumpgas. Something that can do an easy 7K+ on a daily basis.
Old 09-30-2008, 01:02 PM
Check these guys out, http://www.uncommonengineering.com/
One of the Hudson engines that they did had an aluminum head, stroker crank, dry sump oiling, Eaton supercharger and EFI.
Old 09-30-2008, 04:14 PM
PutPut72's Avatar
Earplugs are in the glovebox
I'd like to see a 86 & up SBC stroker build. But not the typical 383 (I've got one and am curious about bigger) I'm talkin' in the range of 421,427,434 cubic inches. I don't think I have seen them in the 86 & up roller SBC's before, that's what I think would be pretty cool.....But I am a Chevy Guy so I do have slight tunnel-vision.
Also what would be pretty killer ,is if they would try some of the new fuel injection systems out on the market.....Edelbrock just came out with a revision on the Pro-FLO system and a spin on the Ram-Jet style set-up...I would love to tune and not have my hands smell like gas ...Too bad I didn't wake up today and crap out $3000!!!!
Old 09-30-2008, 06:57 PM
Twisted Minis's Avatar
A different breed
Last journal entry: New Truck
Straight sixes, eights and twelves would be cool. I'd love to see a flat 6 or 8 build.
Nailhead.
A Toyota 22R. Kind of out of the norm for a magazine like Hot Rod or the like, but there is a big aftermarket for them, and they can be built considerably well without that much money.
Briggs & Stratton flatheads. Simple but fun, and anyone can build a cold blooded, lopey, loud and obnoxious B7S for like $200. Its a fun project.
Caddy Northstar.
Ford Y-block, or flathead V8.
1957? GMC truck impala59 General Rodding Tech 22 04-07-2012 05:29 PM
Joining engines ckucia Engine 23 11-27-2005 02:57 PM
Used Engines Place? TwistedDragon Engine 0 05-25-2004 03:27 PM
Magazines to build by tm454 Hotrodders' Lounge 11 11-03-2003 02:01 PM
what do i need to build a twin turbo 350 chevylovingfarmboy Engine 2 03-16-2003 01:18 PM
