No problem, good luck.
That was my initial question. I'll give it a try then.
norway parts stores
Building a hot rod is probably a challenge where you live. I looked at your build pict's IT all looks good
Thanks!
![]() As an alternative, is it possible to heat the hose to make a bend on it? not much. Maybe 10-15 degrees. |
Unicoil - Bend hose into any shape! Goodyear E-Z Coil U-Bend Hose Coil from HBD/Thermoid, Inc. Gates Unicoil - when curved/molded hose isn't available. (I think this is also in the catalog I linked to earlier) |
Hey Cobalt.
Those are quite handy. Thanks for posting them. |
Dave W |
That is correct. Just forget about part stores the way you know them. We don't have those in Norway.
Here they won't/can't find anything without a part number or the cars' production year/type. Searching a car part based on the part's look is simply not possible. The way I see it, I have 2 options: 1. Try fitting a reducer. 2. Enlarge the firewall holes to accept a 3/4 hose, and use that all the way. |
| Recent General Rodding Tech posts with photos |
| "Mustang II" power steering hose fitting sizes | fleetsidelarry | Suspension - Brakes - Steering | 6 | 12-20-2010 09:54 AM |
| Stepping down a fuel filler hose 2.25" to 1.5" | wyomingclimber | Engine | 11 | 02-13-2008 05:01 PM |
| How does a "Generator" work on a wall heater? | MARTINSR | Off-Topic | 4 | 10-22-2007 08:11 AM |
| 1964 Impala "Heater Control" Unit | 64Joker | Interior | 2 | 01-08-2007 06:20 PM |
| 9" rear end "drag race gear" what does that mean? | 84Z | Transmission - Rearend | 2 | 01-29-2006 04:08 PM |
