Enlarge heater hose end from 5/8" to 3/4"? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2012, 12:18 PM
staleg's Avatar
Last journal entry: Home made gear stick
Due to very limited space around my heater, I need to enlarge the 5/8" heater hoses to 3/4" on one end. There isn't enough space for an adapter fitting.
Is this possible, for instance by using heat?
Or is it possible to have a couple of 5/8" heater hoses custom made with a short area of 3/4" diameter in one end?
Old 12-08-2012, 12:27 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Trying to stretch a 5/8" heater hose out to 3/4" will weaken it IMHO. You might get it to physically fit, but the strength would be compromised I believe.
No room for a reducer like this (they also come in brass that are shorter)?
Old 12-08-2012, 12:36 PM
staleg's Avatar
Thanks for your quick answer. I don't think it's room for the reducer.
But what about these that I just found on Summit Racings homepage:
Summit Racing® Heater Hose Adapters SUM-390007 - SummitRacing.com
Heater hose adapters. But I don't understand from the photo how they work...
Do you simply put the 5/8" hose into the 3/4" hose and clamp the connection?? Will that be leak free?
If so, I might have enough space for this.
Old 12-08-2012, 12:39 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
Looks like you change the whole 5/8 hose to 3/4" and then use a small pce of hose inside the 3/4 hose to fit at the 5/8 end and of coarse the new 3/4 hose will fit the big end as req'd.
My guess.
Old 12-08-2012, 12:41 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The Summit connector would use the 3/4" hose that's included over the nipple on the heater, then the included 5/8" OD piece is pushed halfway into the 3/4" hose, then your 5/8" hose is pushed over the other half of the included 5/8" OD piece and the whole thing clamped down.
Old 12-08-2012, 12:51 PM
staleg's Avatar
Thanks for your answers.
Unfortunately, the holes in the firewall aren't large enough for 3/4" hoses.
If I understand Cobalt 327 corrct, I'l try the Summit reducer.
Old 12-08-2012, 01:08 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The Summit part still requires you to put the 3/4" supplied piece of hose onto your heater barb. It seems to me if that would fit, so would a length of 3/4" heater hose. I must be missing something...
Old 12-08-2012, 01:39 PM
There are many heater hoses that are 5/8" on one end and 3/4" on the other.
This could be one, don't know the exact sizes.
Anyway, make a pattern of your hose out of some brake line or something stiff and go to your local REAL parts store (not a McParts store like the Zone) and ask to see their hose selection and they will be happy to let you go thru them to find something that will work.
Now, often you will buy a longer hose than you need and cut it to length. My brother sells moulded hoses like the originals for 50's and 60's Buicks made from hoses right off the rack at the local parts store. He spent the time to hunt them down, he now buys hoses for late model applications and cuts them to length to fit right on the old Buicks.
At the NAPA store I worked at we had hundreds of these hoses, heater and radiator and would do this all the time for people. You would be very surprised at how many vintage cars radiator hoses can be made up this way.
The Following User Says Thank You to MARTINSR For This Useful Post:
cobalt327 (12-08-2012)
Old 12-08-2012, 02:00 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Good point, Brian. I once had to make do w/a molded hose that was originally for a 3.0L Voyager, to use for the bypass on my 468 BBC in the Camaro. Worked so good I left it on.
Old 12-08-2012, 02:48 PM
staleg's Avatar
What would be perfect for me is 3-4 ft of straight 5/8" hose, with a 3/4" enlargement in one end.
Old 12-08-2012, 03:05 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Gates Dual I.D. Heater Hose
Specially designed for heater hose applications requiring changes in diameter.
For part numbers, see page A26, here.
Old 12-08-2012, 04:08 PM
You need to get down to a real parts store and they will likely have just what you need. If they don't have it in stock they will be able to get it for you.
Old 12-09-2012, 01:56 AM
dinger's Avatar
I may be missing something here, but why would you not run a 3/4 inch hose from the heater core, say about 10 inches long, then put this reducer and run 5/8 from there on out?
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 12-09-2012, 05:00 AM
staleg's Avatar
The holes in my firewall accepts no bigger than 5/8" hoses, and the distance from the heater outlest to the inside of the firewall is very short. That's why.
I'll check out the Gates part numbers. Thanks for the link!
Old 12-09-2012, 05:03 AM
123pugsy's Avatar
Wiki Edits: 29
Try warming it up with a heat gun. It should soften up enough to go on. I've done it with a lot of hoses with no issues.
"Mustang II" power steering hose fitting sizes fleetsidelarry Suspension - Brakes - Steering 6 12-20-2010 09:54 AM
Stepping down a fuel filler hose 2.25" to 1.5" wyomingclimber Engine 11 02-13-2008 05:01 PM
How does a "Generator" work on a wall heater? MARTINSR Off-Topic 4 10-22-2007 08:11 AM
1964 Impala "Heater Control" Unit 64Joker Interior 2 01-08-2007 06:20 PM
9" rear end "drag race gear" what does that mean? 84Z Transmission - Rearend 2 01-29-2006 04:08 PM
