Enough compression? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2006, 01:22 PM
Enough compression?
I'm worried about the compression ratio my engine might have.
Im building a 383 stroker blower motor. But i wont have anough money for the blower until after next summer. So i was going to buy everything i need,run the engine until im ready for the blower.
So here's what I have for now, let me know if you think the compression will be too low without a blower for now.
4340 3.75 crank
4340 h beam 5.7 rods.
Forged speed pro pistons with 8.92:1 with 64cc heads(adding 72 or 76cc heads with blower).
blower cam: Intake Duration at 050 inch Lift: 234 , Exhaust Duration at 050 inch Lift: 244 , Advertised Intake Duration: 292 ,Advertised Exhaust Duration: 302 ,Intake : 0.488 in. , Exhaust Lift: 0.510 in., Lobe Separation:114 .( is this cam to big? i have 4.11 gears in the rear).
not sure on intake for now, probably high rise or edelbrock performer rpm.
holley 670 cfm carb.
Is the compression too low to run with out a blower, and also can some1 dyno this for me. Thanks alot.
Old 10-02-2006, 02:00 PM
johnsongrass1's Avatar
Race it, Don't rice it!
It's likely to run, but not without the compromises from the missing part's.
Old 10-02-2006, 03:02 PM
what do you mean missing pats?
Old 10-02-2006, 03:03 PM
.....*parts
Old 10-02-2006, 03:54 PM
I think hes talking about the absence of the blower. Your compression is pretty low for the cam. If your gonna switch the heads for larger com chambers later why not switch the cams as well when your ready to install the blower?
Old 10-02-2006, 07:02 PM
firestone's Avatar
http://teamrfc.gospelcom.net
I think it might run ok. Just comparing to compression requirements from comp cams, it looks like ~9:1 will work. Below are a couple of comp cams and compression requirements for them.
286H (236 236 @.050 .490 .490 lift 110 lsa) recommeded 9.0:1 comp
XR288HR (236 242 @.050 .520 .540 lift 110 lsa) recommended 9.0:1 comp
your cam, being 234 244 @.050 .488 .510 should be ok with your compression. More would be better, but I dont think this will be horrible. I think the high lobe separation may also help with low speed torque. A hp estimate is hard to guess without knowing exactly what the heads are. As far as the intake goes, I would run the perfomer RPM.
Adam
Old 10-02-2006, 07:43 PM
Thanks alot for all of your help. i really appreciate it. Im only a 20 year old kid, trying to make a big statment, as well as doin this for myself. I havent seen too many blowers in camaros around here,let alone in a 73. Thanks guys
Old 10-02-2006, 08:30 PM
To answer your question, yes it will run.
53_belair is exactly right though. Why not swap the blower cam in later once youve got the blower and run something smaller for the time being?
With the cam you described, even with the gears the car will be very soggy down low. It will run, and itll lope like a harley with a miss but it will NOT be very fun to drive.
If you havent already pulled the motor from the car, Id leave it. Id pick up another 350 block (not hard to find) and build it. That way you can still drive the car while you assemble parts for the 383.
Old 10-02-2006, 08:34 PM
I already pulled the motor from the car, since it is already bord .30 over, and is pretty fresh. maybe ill just go with a nitrous cam for now, then switch. What cam would you suggest.
Old 10-02-2006, 09:50 PM
4-speed or automatic? If auto, are you prepared to use a stall converter?
Old 10-03-2006, 04:20 PM
4 speed rock crusher
Old 10-03-2006, 08:40 PM
I may have missed it, are you running rebuilt factory heads or aftermarket?
If it were mine to build Id pick a cam somewhere in the ballpark of 225 degrees duration @.050 and .475 or so lift. Slightly smaller would be better than slightly bigger.
You wouldnt have to rev it to the moon to make good power. Dont give up the torque of a 383 by stuffing in the giant cam of death. Remember, RPM stands for 'ruins peoples motors'!
If youve got factory chevrolet heads, Id look hard at a split pattern cam.
Old 10-03-2006, 08:56 PM
OK thank alot for all of your help
Compression question for the Pro engine builders.. Axelrod Engine 14 01-16-2007 11:29 AM
Compression concerns. Siggy_Freud Engine 4 07-11-2006 11:06 AM
Interesting compression question Jmark Engine 11 04-26-2006 04:27 AM
351 windsor running rich ???? ve3ham Engine 19 08-08-2005 01:48 PM
How to figure compression ratio...... classic_chevy_guy Engine 9 07-26-2005 10:59 PM
