enough retainer to seal clearance? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2009, 07:44 PM
So I have measured out the clearance on my vortec heads using the type seals shown below and have come up with this.
The intake valves have 18/32's or .5625" travel before the retainer will hit the seal.
The exhaust valves have 16/32's or .500" travel before the retainer will hit the seal.
I have read somewhere that these seals cannot be ran on these heads without machining the guide boss. Is this true?
And if I can use these type seals will I have sufficient enough clearance to run an XE262 cam which gives .462/.469 lift.
Name:	valve seals.jpg
Old 02-11-2009, 08:01 PM
you will be fine with that clearance.
sam-missle
Old 02-12-2009, 10:54 AM
anyone know about the seals and if they will work?
Old 02-13-2009, 03:28 AM
Those are just stock replacement seals, nothing special.
If you have a few bucks to spend, have them machined for
PC type teflon seals. I think I only charge $40 to do that, so
a shop in your area should be similar.
Valve Spring Locator, Retainer Clearance Specs SSedan64 Engine 5 06-10-2008 03:49 PM
Umbrella Seal Clearance inside Valve Spring dirtydave Engine 3 08-28-2007 06:17 PM
Rocker to retainer clearance MEAN_SBC Engine 4 02-22-2005 08:47 AM
Front oil pan seal on Small Block Chevys gearhead77 Engine 19 09-26-2004 08:58 PM
Where do I find a Seal Beam Retainer sifua Electrical 0 11-11-2003 08:23 PM
