Entry Level Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2004, 04:22 PM
MI2600's Avatar
Member# 3287
Do the SBC and BBC starters interchange?
Old 06-17-2004, 04:45 PM
stepside454's Avatar
generally yes
Old 06-17-2004, 08:18 PM
jlraiders04's Avatar
New Member
Last journal entry: oo
i had this problem
it all depends on the size of the flywheel or flexplate stock starters arent interchangeable. summit sells a starter that can go on both 153 and 168 size flywheel it saved me
Old 06-17-2004, 08:22 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Yes
Troy
Old 06-17-2004, 10:30 PM
MI2600's Avatar
Member# 3287
I should have included that it's for a 168 tooth SBC on a 383.
I was wondering if a BBC starter might have more "oomph" and also fit, or at least fit an SBC starter nose.
Old 06-19-2004, 09:29 PM
New Member
heres the problem
on my car a 75 vette now with a zz383 the bell housing was a problem im not sure what ur building
Old 06-19-2004, 11:41 PM
troy-curt's Avatar
The heavy duty SB starter is the same as a BB.
There is a short starter and long starter, they will fit either one depending on what flywheel you have.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
