Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - epoxy alone?
Thread: epoxy alone?
Old 07-23-2012, 07:35 AM
Mach1460's Avatar
Mach1460 Mach1460 is offline
Last journal entry: Project 92' Eddie
epoxy alone?
Im putting new inner fender wells and quarter patches on my bronco, im wondering if I should completely remove the black paint or coating that came on the new panels and epoxy them then use weld thru primer on the areas that I use to attatch them. OR should I just leave the black paint/coating on the panels and use weld thru on areas that need it? Im mostly concerned with the upper half of the inner fender well since the bottom/visible side will get a bed liner type coating.
How long will epoxy hold up against the elements on its own?
