Epoxy based paint PJ1? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-15-2003, 04:17 PM
daimon1054's Avatar
I was looking at a few motorcycle sites and saw that PJ1 makes an epoxy based primer and paint in a rattle can. Does anyone know anything about this stuff? Their site is down so no info there. The price is right 7 bucks for a can so for small parts I think it would be a great deal and I pretty much only do small stuff.
So I was wondering if this would be an alternative to mixing up primer for small jobs? How good is this stuff?
Old 11-16-2003, 08:52 PM
Epoxy Paint
I can't comment on the PJ1 paint ,I've never heard of the stuff .
I can tell you that REAL epoxy is a 2 part system ,base material ,and catalyst .How does this work in a rattle can?????
If you are doing ONLY small areas ,I do know that there are some spot primers out there that are compatible with automotive type paints .But you should see your local auto paint jobbers ,as the brands/names may be different in your area from mine . Rick
Old 11-17-2003, 12:34 AM
milo's Avatar
point on positive
I've had some good results using Sem's flexable bumper primer on little spots and small parts instead of getting a gun dirty like your thinking. Even though it's designed for bumpers it acts nice...
http://www.semproducts.com/sempages/semtrimpaint.html
Old 11-17-2003, 12:54 AM
daimon1054's Avatar
F1 I don't know how the rattle can would work, my motorcycle uses a urethane clear and that requires a hardner but I can buy it in a can so not sure what the deal is.
milo thanks for the info.
Old 11-17-2003, 06:09 AM
302 Z28's Avatar
Re: Epoxy based paint PJ1?
No matter what it says on the can, it is not true epoxy. Epoxy requires a catalyst. When the catalyst is mixed with the resin a chemical reaction is triggered that cures (hardens) the mixture. Epoxy does not require air to dry. There is no way to put a true epoxy primer into a rattle can. Also there is no rattle can primer, bar none that I would trust under a paint job.
Vince
Old 11-17-2003, 06:34 AM
daimon1054's Avatar
Well if Honda, Yamaha, Kawasaki, KTM and Suzuki all say it is epoxy I am thinking it is.
I think these guys http://www.armorpoxy.com/html/about.htm might disagree with you as well. They offer a 1 part epoxy paint and they say you don't even need a primer and the coat will last 20 years.
Again I don't know how it is supposed to work but then again I don't know how fat people have sex either but I know they do
Same for the UC150 urethane clear, how can I buy that in a can and not need a catalyst?
