Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Epoxy over lead filler
Old 04-13-2013, 06:19 AM
rodgrdodger rodgrdodger is offline
Originally Posted by BarryK View Post
Body filler or 2K primers its not an issue.
I have changed my literature and I do know ***** is going to and one of the **** guys at the Radtec meeting said they were.
Reason is a letter was sent out by one of the epoxy resin company's about two months ago acknowledging some problems.
In short (I don't have letter here) i will try and sum up.
Metal coatings are changing such as high strength and different types of coating for rust protection from the OEM. What is happening is let say you sand with 180 the epoxy may not get into the finer scratches and adhesion is lost and corrosion protection is limited because of air trap-page that will lead to delamination.
Compounding this problem is the voc laws. The high solids resins add to the problem even more so than the finer scratches.
Also noted in the letter, it has been assumed in the past epoxy adhesion was 45-50% charge +/- as all items have a charge except things like TPO, TEO etc. Now they feel the charge rate is in the 35-45 % range.
Another problem (this is my opinion) is the so many different types of sand paper being used. The cheaper ones break down faster and if not changed enough the metal almost looks buffed with scratches.
There is no reason not to use 80, in past its been said on here that 80 is to rough but I have never (IN BARE METAL) seen an 80 scratch that was not covered with one coat of epoxy. Now in body filler or primer thats a different subject all together.
I deleted the names of the other company's as, really not my place to say, but you will see over next year different procedures being recommended.
What your using-go to 80!
I suppose you could thin out the epoxy slightly if you're worried about penetration but it should be ok using standard amount of reducer. I have had great result's with fusion just following the maker's instructions.
