epoxy prime 1 pannel at a time - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2004, 08:46 PM
montea's Avatar
tryn to learn
ok i want to prime my front quarter pannel that i been working on, its bare metal with body filler in the low spots.
what grit should the bare metal and body filler be for primering? i got wax and grease remover stuff to clean the bare metal before priming, do i wash the body filler on the pannel as well? how long to let dry?
the primer is dupont epoxy primer. how much should i mix up to do this 1 pannel?
Old 08-15-2004, 04:10 AM
BarryK's Avatar
Re: epoxy prime 1 panel at a time
Metal and filler- people use 80-180 as far as grit, so whatever you have in that range will work fine.
Wax and grease remover drys pretty fast so a lot of painters wipe off, tack and prime thats OK if doing an allover because of the time it takes to tack. Perhaps overkill but I like to give the car about 15 minutes after using wax and grease remover just to make sure everything is gone. OK to wash filler.
Spray-able pint will be plenty.
Old 08-24-2004, 03:42 AM
montea's Avatar
tryn to learn
ok i got my quarter pannel bare metal sanded with 120grit paper
so i should mask everything off that overspray could get on, clean the metal, go mix the primer up, hook the gun up and start sprayn?
the gun i got is a cambell hausfeld automotive siphon-feed spray gun. just a $60 gun(should be fine for priming i would think). the manual shows where the "pattern control knob" and "fluid control knob", how do i adjust this gun for what i am doing? also how do you clean these after use?
should i put 2 coats on the pannel? how long before coats?
sorry for all the questions ive never done this before.
thanks for the replys.
Old 08-24-2004, 04:17 AM
BarryK's Avatar
Masking of car?
For epoxy i use just a sheet of 18" paper around the panel I'm premiering. Since your using a siphon gun and your new I might go ahead and throw some plastic over the rest of car.
Air pressure: For that gun you have start with 20lbs and adjust up till it sprays the epoxy how you want it. I would guess 30 lbs is going to work for you.
Clean the metal with wax and grease remover and shoot the
Dupont epoxy I would wait about 5 minutes at 70 degrees before
spraying 2nd coat.
