Epoxy Primer and Etch Primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2005, 01:14 AM
New Member
Is it overkill to use etch primer under epoxy primer? I've been spraying the insides of my doors and my patch panels this way and I was wondering if this is correct.
Thanks in advance.
Old 07-07-2005, 05:35 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Overkill
Yup I think so..and some etch primers do not live well with epoxy..I have been using SPI 6600 series epoxy which is a self etching epoxy primer..
Works just fine..and this stuff can be used on any of the parts needing paint..
OMT
Old 07-07-2005, 05:48 AM
Epoxy doesn't require etch primer under it, is this a wash type primer or a self etch primer surfacer? What products are you using? Most epoxies will work over a self etch or wash type primer if applied within the recoat window.
Epoxy adheres very well to properly prepped steel, properly prepped meaning the surface is sanded with 80grit and cleaned very well. The only times I've see epoxy fail adhesionwise on steel is when the prep was poor. Scuff up the surface well and clean untill you can rub a clean white towel on the surface with no discoloration on the towel, then your ready for primer. Wash primers and self etch primer surfacers are generally a little more forgiving when it comes to prep, the high amount of solvent and acid help if the prep is poor. JMO's
Old 07-07-2005, 01:09 PM
New Member
I was using a 2k Nason Etch Primer and DP90LF Epoxy primer.
I wanted the etch primer on there for the extra corrosion protection since it was on the bottom of the door where I'm putting the skin on.
Self Etching or Epoxy Primer Ron M Body - Exterior 14 11-30-2010 06:23 AM
Bare Metal Mollard Body - Exterior 71 09-25-2008 01:48 PM
"Basic of Basics" What kind of paint should I use? Centerline Body - Exterior 5 10-21-2007 11:32 PM
primer question 347mustang Body - Exterior 3 07-05-2005 08:17 PM
primer sealer, epoxy or self etch? CAMARO Body - Exterior 3 03-11-2003 06:34 PM
