Epoxy Primer / Etching Primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2005, 12:03 PM
New Member
I see a lot of references to Epoxy Primer. I took a body class about a year ago, and we used etching primer. Are they one in the same?
Also, what is the best way to remove rust from areas like inside the doors? If it's just surface rust, does it need to be removed?
Old 01-27-2005, 03:58 PM
willys36@aol.com's Avatar
Wiki Edits: 21
These are all great questions and they have been covered in depth in very many posts on this board. Do some searches using various key words and you will find answers to the basics you asked plus a bunch of other wisdom that would otherwise be missed.
Old 01-27-2005, 05:07 PM
New Member
Well, I found information on the epoxy and etching primers, but I didn't find any good tips on how to get rust out of the inside of doors (or whether it's worth the effort).
Old 01-27-2005, 05:25 PM
BarryK's Avatar
At the very top of this page, was written by one of the foremost
metal experts.
R. Ferguson.
"secrets of rust removal"
