Epoxy primer over 400 scratches? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-16-2011, 11:33 PM
Prep
Find a good sealer and seal over 400 grit 1 nice coat then paint after sealer has dried 15min. The rule is paint over 400-up. I base over 400 some times depending on base, if it's a light metallic paint over 600 or just seal the 400 and then apply base coat. If it's a solid or dark metallic primer sanded with 400 and goooooooo!
  #17 (permalink)
Old 11-17-2011, 08:34 PM
Thanks all, I decided to spray some reduced epoxy, and let that dry overnight and then spray some 2k and wetsand it supercarefully with the 600 later
  #18 (permalink)
Old 11-19-2011, 09:24 AM
deadbodyman's Avatar
Wiki Edits: 11
Just pay close attention to your reduction ratios its very easy to get it mixed up when everything you use has a diferent ratio...Even after 35 yrs of doing this work I get complacent and start day dreaming while mixing stuff....PAY ATTENTION.....This is what happens when you mix a 1:1 epoxy at 4:1......
Someone said using epoxy is like putting a condom on your car for protection...I never knew just how true that was till I screwed this up...
ID:	59972   Click image for larger version
  #19 (permalink)
Old 11-19-2011, 01:12 PM
Old Fool's Avatar
sure makes you appreciate razor blades !
  #20 (permalink)
Old 11-19-2011, 06:10 PM
Wiki Edits: 11
Speaking of razor blades....You wouldnt think such a small little thing would be SO important but ALL razor blades are NOT equal.....GET GOOD ONES...
I bough a box of 100 at lowes and they were the worst junk I ever used ...
stripping some peeling clear ,they nick after about two passes I had to throw them out, they wouldnt even cut masking paper without tearing it.
I got some good ones (PPG) and I stripped a whole hood today with one blade and never scratched or nicked the base coat...
The reason I mention this is I can only imagine someone that didnt know trying these and not knowing how they are supposed to work and nicking and scratching the whole job making all that extra work especially when stripping that last layer of epoxy or primer of the steel...a nicked blade is bad ,even for your sheetmetal
Flash rust OK under epoxy? SPI epoxy primer, Transtar 6131, or PPG Shop Line? off2wildblue Body - Exterior 2 07-29-2010 09:53 PM
can i spray epoxy primer over etching primer without sanding? wickiewicked240z Body - Exterior 1 08-29-2006 10:07 PM
Scratches showing through primer. RodFather Body - Exterior 8 04-03-2006 10:13 PM
400 Scratches in primer see through base!!!Help SouthernRodder Body - Exterior 17 02-15-2006 01:20 PM
Scratches in the primer filler after blocking Scode68 Body - Exterior 38 11-20-2005 10:05 PM
