Epoxy Primer Over Lacquer - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2007, 02:37 PM
I stripped off a coat of red lacquer from my 1979 MG . Under that I found the original light blue lacquer paint. There is some Bondo on some areas and also some areas where the bare metal is exposed. I'm planning to re-coat with a Base Coat/Clear Coat Urethane. Should I paint over the old paint ? If I do so, could I use Epoxy Primer over the old lacquer paint?
Thank you for any help.
Old 05-28-2007, 10:21 PM
Countilaw's Avatar
Cox Custom Cars
I would seal the old finish with epoxy primer/sealer. The polyurethane will not attack the lacquer like lacquer attacks enamel. But it's a good idea to seal everything under your new base coat.
Frank
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 04:07 AM
Having problem with epoxy primer...... onebadmerc Body - Exterior 22 05-19-2011 02:31 PM
Self Etching or Epoxy Primer Ron M Body - Exterior 14 11-30-2010 07:23 AM
Epoxy vs Urethane Primer UKLuge66 Body - Exterior 41 11-23-2008 06:50 PM
epoxy primer over lacquer primer? johnnyford Body - Exterior 3 01-05-2007 06:11 PM
