Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 09-13-2007, 05:32 AM
Slickriffs's Avatar
Slickriffs Slickriffs is offline
Epoxy primer over lead?
My 55 truck (Chevy)comes back from the blaster today. I have some minor welding to do after which I like cover with lead to fill the pin holes. I also have had to rebuild some delicate areas of the rear door post. The post where the door seal/weatherstripping would come up against when the door is closed. I'll weld in some strips and then lead the repair since it's easy to shape.
I've got some SPI epoxy primer on the way..any special precautions relative to covering the lead with paint other than the usual wipe down with the wax remover and nuetralizing the lead with vinegar?
Thanks,
Keith
Old 09-13-2007, 04:08 PM
vondutchrodder vondutchrodder is offline
Location: 926 Shells Bush Road, East Herkimer,N.Y.13350
re: Epoxy primer over lead?
When you are done with your lead work You will then clean your whole working area with a muriatic acid cleaing solution and a scrub brush doing a super job of cleaning all acid residue from the body. You can then wash surface with soap and water also.You have to be absolutely sure that you removed all of the tinning flux from all of the affected surfaces and any pits left in the lead.Otherwise anywhere from 2 to 10 years you will get a surface bubble in your painted surface where there was a small amount of flux left from the tinning operation. Dutch
Old 09-13-2007, 04:31 PM
35WINDOW 35WINDOW is offline
Hey!
This looks like Dutch! How are you doing? Glad to see you over here, we could use your knowledge-thanks for posting and Welcome!
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Epoxy primer over lead?"
Epoxy vs Urethane Primer UKLuge66 Body - Exterior 41 11-23-2008 05:50 PM
Having problem with epoxy primer...... onebadmerc Body - Exterior 16 08-28-2008 11:52 AM
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 108 06-25-2008 04:37 PM
epoxy primer wisch79 Body - Exterior 2 02-22-2006 11:19 AM
Self Etching or Epoxy Primer Ron M Body - Exterior 1 08-16-2004 05:03 AM
