Is this 'epoxy' primer... really? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2014, 06:33 AM
Grand Master of the Universe
Just checking.... Is the term "epoxy" being thrown around too much? I'm seeing at least two kinds of primer being discussed... 2K epoxy, and 2K urethane.
The 2K I'm using (2K ISO free) uses a 3:1 hardener. I'm assuming this is a true epoxy.
Are other 2K primers NOT 'epoxy'?
Perhaps a primer on terminology is in order.
Old 01-27-2014, 07:55 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
2k refers to an activated product . anything with hardener is 2k.
epoxy is a resin .
Old 01-27-2014, 09:53 AM
carolinacustoms's Avatar
Automotive Extraordinaire
To addto Shine's post, most epoxy mixes 1:1.
Kelly
spraying epoxy primer over epoxy primer 65 f-100 restore Body - Exterior 11 12-07-2013 01:37 PM
What is the difference between singe stage epoxy primer and 2 stage epoxy primer rusthater89 Body - Exterior 16 06-01-2012 09:06 PM
HOK Ko-Seal Primer Sealer vs Epoxy Primer 67Elcamino Body - Exterior 0 02-02-2012 11:34 PM
Flash rust OK under epoxy? SPI epoxy primer, Transtar 6131, or PPG Shop Line? off2wildblue Body - Exterior 2 07-29-2010 08:53 PM
can i spray epoxy primer over etching primer without sanding? wickiewicked240z Body - Exterior 1 08-29-2006 09:07 PM
