Epoxy Primer Sealer - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2011, 07:38 PM
Epoxy Primer Sealer
If You Are Sanding A Car Down To Apply Epoxy Primer Sealer Then Bc Cc,what Grit Sand Paper Could You Use That You Don,t Get Sanding Marks In Your Bc Cc.the Primer Sealer I Am Useing You Don.t Sand Before You Start Painting.
Old 06-11-2011, 09:17 PM
i use 400 wet.
Epoxy primer as a sealer ? Daz_uk Body - Exterior 4 01-16-2011 03:11 AM
Epoxy primer as sealer spanky36 Body - Exterior 3 02-11-2010 02:58 PM
epoxy primer used as a sealer rxlmod Body - Exterior 6 12-18-2009 06:35 AM
Epoxy Sealer-Primer With 2K Build Primer on top kilgorq Body - Exterior 4 04-29-2008 05:30 PM
