Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Epoxy Primer/ sealer Q
Old 04-18-2012, 05:53 AM
swvalcon's Avatar
swvalcon swvalcon is offline
Last journal entry: rust on lt body shell
Is your omni. a sigle stage black or are you going to do it in base clear? I've do some used car paint work this way when their older and on a budget. If it's siingle stage I would lightly hit it with some 600 after I used my 400. When you put down your paint dont use to heavy of a coat on your frist coat and let it dry good before you do any more coats. Maybe up to and hour. Give all your coats of paint plenty of dry time this will keep sand scratches from swelling up. Good luck.
