Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Epoxy Primer/ sealer Q
Old 04-18-2012, 09:53 AM
cyclopsblown34's Avatar
cyclopsblown34 cyclopsblown34 is offline
Colorsanding painter
I'd say scuff up the rock chips with 180 and use a catalyzed spot putty like Dolphin Glaze or any other decent catalyzed spot putty. I'd then urethane primer/surface the hood with the same primer you've been using, sand up to 400 grit and spray your paint. i don't go to 600 grit unless spraying metallic and then make certain the sanding is in a circular pattern sort of like a DA sander.
