Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Epoxy primer in stages
Old 06-21-2005, 02:16 PM
baddbob baddbob is offline
Doing it in stages is no problem, when your section is bumped, welded, sanded, and cleaned spray it with epoxy and move to the next panel or area. The only thing you need to do is scuff the older epoxy with a red scotchbrite pad before applying more epoxy or overlapping on the edges. Scuffing is fast and easy and will guarantee good adhesion. Bob
