Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Epoxy primer in stages
Old 06-21-2005, 03:26 PM
kenseth17 kenseth17 is offline
Yep, actually a good way to do it, Put epoxy primer on as soon as possible so you don't have bare metal out in the open and getting moisture. And you can apply filler over the epoxy, just rough it up. Then once everything is done and epoxy sand it and apply your filler primer if needed, or paint if everything is that straight. If you have bodywork areas you are probably going to be spraying a urethane filler primer, plus it sands easier then epoxy primer does.
