Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Epoxy Primer, Urethane Primer Compatibility
Old 11-22-2010, 01:24 PM
brimcp99 brimcp99 is offline
Thanks for the reply, Ive always done my body work on bare metal then feathered it into the existing paint sanded with 80 grit (assuming its a urethane in good condition still). Ive been reading with interest about using epoxy underneath for better adhesion and rust prevention.
I was hoping to use the 2k urethane primmer "wet" over the epoxy primer as I have no need to wait as my body works all done. Most data sheets say they can be top coated wet on wet from 1-24hours after application but donít specify if the urethane primmer has to be from the same product range.
