Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Epoxy Primer, Urethane Primer Compatibility
Old 11-22-2010, 04:37 PM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
I dont use epoxy on repair work just the urethane works fine. I use the epoxy on everything I strip to metal...The products and brands you use over there are different so whatever the tech sheet says would be the way to go.I can mix and match different brands because I know them but I cant really tell you anything about what your using and guarantee the results
