Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Epoxy Primer, Urethane Primer Compatibility
Old 11-22-2010, 05:10 PM
brimcp99 brimcp99 is offline
Thanks, im probably going to get some Valspar VP50 epxoy primer and some Valspar HS35 2k filler primer to go over it so I know there wont be an issue, the data sheet says the epoxy can be topcoated after 2 hours so im guessing the filler primer is the same, I have emailed them to confirm.
Anyone got anything good or bad to say about the Valspar producs ive mentioned?
