Epoxy Sealer-Primer With 2K Build Primer on top - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2008, 12:58 AM
kilgorq's Avatar
I am painting my truck. I used PPG Omni MP170 Epoxy to seal the bare metal. I have a gallon of 5 Star High 2K High build Primer to spray over it for blocking and minor scratch fill.
Has anyone used these together. Has anyone had any problems with this combination.
I snagged my air hose on a the corner of the bumper causing me to create a small run in the MP170. Should I wait for it to fully cure (3 Days) and sand it or would it be ok to go ahead and put the 5 start over it and fix it when I block it out.
Any tips on Painting a hood on a tall truck. I can not reach the back of the hood without a ladder. I would assume that I would use a step ladder and work the dry line from the front of the hood to the back. Work the dry line right off into the windshield area. Or would it be better to remove it and shoot it off of the truck.
Old 04-28-2008, 02:57 AM
shadowismydogsname's Avatar
hi,yes removing the hood would be a better idea..well i think so but others might disagree.The epoxy primer and the high build primer i would think they would be okey with each other but don't take my word for it...hopefully someone will come alone and tell you the correct way.
thanks..
Old 04-28-2008, 02:14 PM
I've used the 5 star 2K before. I would rather put laq primer over a panel than use 5 star again. I had a bad experience with it when I first opened my shop. The paint chiped right at the door lock all the way back to the primer and by the time It was finished it had peeled all the way to the center of the door. For cheap primer I use montana 2 part. Its high build, cheap in cost, and sands really nice and so far holds up to a pretty good beating with the bulls in the china shop that I've got working for me.
Old 04-28-2008, 06:30 PM
BarryK's Avatar
To answer the question yes that combo will work, I won't get into quality or anything else but if used in the right manner you will be fine.
My suggestion would be, spray a coat of the epoxy and a second coat after 30-60 minutes.
Let set overnight.
Spray primer next morning but give at least 10-20 minutes between coats, yes, overkill and not necessary but to your benefit if you have the time.
Old 04-29-2008, 05:30 PM
kilgorq's Avatar
What should I use. I have sprayed the MP170 on most of the truck but I would rather make sure I am using the correct stuff now than later. If I have to take a step backwards now. It is a lot easier to do. Please let me know the pros and cons of other types of primer and paint. What corners not to cut with brands of paint. I plan on keeping this truck for a very long time but I am on a budget also. At this point I would like to get it in primer even if I prime it with the MP170 and wait until I have the money to get the better paint and primer later. I am trying to get the metal protected right away.
Is the quality issue with the MP170 or the 5 Star high build.
Window time for 2k over epoxy cu42 Body - Exterior 3 12-21-2007 07:11 AM
2k Primer, to Wet? satexasf150 Body - Exterior 2 05-19-2007 11:13 PM
PPG epoxy primer mustangguy Body - Exterior 2 05-18-2003 05:25 PM
primer sealer, epoxy or self etch? CAMARO Body - Exterior 3 03-11-2003 07:34 PM
