Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Epoxy sealer/seam sealer/paint equip
Old 10-18-2004, 05:41 AM
mrcleanr6's Avatar
mrcleanr6 mrcleanr6 is offline
using the air dryer you currently have, the trick to removing water is that the air be cool when it enters the dryer. usually a 50ft air hose between your compressor and the dryer will give the air a short cooling period for the moisture to condense before it enters. in the summer you may need longer depending on how hard the compressor is working. in addition to that definately put the small filter that barry was talking about on the gun. its just another safeguard.
