Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Epoxy sealer/seam sealer/paint equip
Old 10-18-2004, 10:43 AM
Aekisu's Avatar
Aekisu Aekisu is offline
Re: Re: Epoxy sealer/seam sealer/paint equip
Originally posted by BarryK
2. My compressor is a 6 hp (11.5 cfm @ 40 psi). What would be a good epoxy primer gun?
Any 1.4 gravity feed gun will work but not enough cfm to consider an HVLP.
Not quite true. If you can locate a Sharpe Platinum LV (which is a HVLP), your compressor will work just fine. The Platinum only requires 7.5 CFM.
Sharpe doesn't produce the Platinum anymore. They sold the rights to Snap-On and Snap-On now sells it. They have given the gun a different name (which I don't recall).
