Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Epoxy sealer/seam sealer/paint equip
Old 10-20-2004, 02:44 AM
julmer julmer is offline
Old enough to know better
Sharpe's new import line, the FineX 300 HVLP uses 11.4 cfm at 29 psi. Your compressor should handle that. It is under a hundred bucks so, if you are not satisfied with the quality, you now have a dedicated primer gun - which you'll want anyway.
