Is epoxy sealer suppose to be shiny? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2005, 07:32 AM
I shot my trunk lid with epoxy sealer. The finish is satiny almost glossy. How am I suppose to expect some kind of high-build primer to stick to fully cured epoxy sealer? Its way to slick. I suppose I need to scuff it up?
I'm only doing a panel at a time because that's my only choice. How do guys shoot a whole car with sealer and then primer it? Do they shoot the primer on before the epoxy fully cures or do they wait till it cures and scuff it?
Old 09-25-2005, 09:03 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Yes,It will semigloss on you.
Most epoxy has a recoat window for recoating,chemical bonding.
After that,it should be scuffed with a red scotchbrite before applying 2K,mechanical bonding.
I will scuff it anyway as I prefer to let epoxy cure a day or 2 before applying anything to it. I have had some lifting even though it is still in the recoat window. More work,but so is having lifting later.
What brand is it?
Bare Metal Mollard Body - Exterior 71 09-25-2008 01:48 PM
"Basic of Basics" What kind of paint should I use? Centerline Body - Exterior 5 10-21-2007 11:32 PM
What grit? before and after epoxy sealer ? 67LS1T56 Body - Exterior 7 08-17-2005 10:04 PM
primer question 347mustang Body - Exterior 3 07-05-2005 08:17 PM
primer sealer, epoxy or self etch? CAMARO Body - Exterior 3 03-11-2003 06:34 PM
