Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Epoxy vs Urethane Primer
Old 07-25-2005, 08:50 PM
BondoKing's Avatar
BondoKing BondoKing is offline
KING OF BONDO
Last journal entry: My little helper
Never trust the guys behind the paint counters ... only rarely will you find one that is competent in this field and works in it as well.. I think you should go with the epoxy primer.. Etching primer is yesterdays technology and the epoxy is superior... If you are looking for quality products,, and I think you are, you can not beat that of www.southernpolyurethanes.com
Go there and check out the products as well as prices... If you want to purchase something then you will need to go here and get the 800#
www.bakerpbe.com .... I make mention that they also carry HOK and just about anything you need for your automotive needs.. tape, paper, paints etc... and their shipping is first rate and cheap... Hopefully Barry will chime in on the primers for you
