EQ aluminum Torker cyl. heads
I've been wanting to make a head change mainly for weight reduction and secondly for a little more HP. I've heard good thing about EQ heads & found some bear EQ alum. Torker heads on EBay for 220.00 ea. Their 197cc w/202 on the intake & 65cc w/160 exhaust, chamber is 65cc. Do you think this would be a good choose for a Chevy 350? I have ported iron vortecs on it now with Comp cams 1.6 roller tipped rockers an Cranes spring kit (550 lift). An a RV cam intake .204, exh. 214, LSA 107. I want to use behive springs on these new heads and set it all up for a retro roller cam. I'd tell the piston specs. but I not sure what they are. This will mainly be used as a cruzer/street car. Looking for suggestions. Stock crank & rods, 2 bolt main, 2500 stall, 700r4 trans, 3.42 gears. 78 Camaro. I want to get the heads an slowly start putting every together.
