Eratic temp gauge - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2005, 04:33 PM
New Member
Eratic temp gauge
I'm running a 302 ford in my F1 with an edelbrock aluminum manifold, and a 12volt system
I had the gauge cluster updated with a runtz attached to each 6 volt gauge.
each was calibrated with new mopar senders.
gas (which is stock) amp and oil all work fine, but the temp will run normal needle in the center and at other times at the hot side, out side air temp doesn't seem to matter. when I shut if off after a trip and return later the temp always goes to the hot side once under way
wondering if the aluminum manifold has any thing to do with this.
I borrowed a laser and read the temp of the engine after a trip and it registered 170deg on the block and manifold.
This more of a nusiance than a problem as the engine doesn't overheat
suggestions?
Thanks
DK
Old 09-16-2005, 05:55 PM
docvette's Avatar
Wiki Edits: 12
Air
Doc here,
Try purging the system of all air.
You may have a small air bubble stuck or cycling around the temp gauge.
A sender can not read air and as it passes and settles it will give erratic readings.
Check that first before going to the electrical.
Doc
Possible for autometer temp gauge to be bad? fouroheight68 Engine 8 02-21-2005 11:20 AM
Coolant Sensor? Temp Gauge what do you think? my350camaro84 Engine 1 02-14-2005 07:50 PM
Which temp gauge is more accurate Palmtrees57 Engine 3 10-30-2004 06:38 AM
Temp gauge grandprix601 Electrical 2 03-17-2004 08:45 AM
1950 Buick temp gauge in engine stuck! reluctant_paladin Engine 1 04-10-2003 08:49 AM
