-   -   erm, should this hole be here?! (http://www.hotrodders.com/forum/erm-should-hole-here-86757.html)
pcoghlan 04-12-2006 08:05 PM
2 Attachment(s)
midway through putting my engine (SBC) back together and picked up the waterpump to have it cleaned and painted and came across this hole?!
hmmm...
is it a problem? I didnt have any leaks before it came apart but I have never seen such a hole before?
confused
Paul
madamstn 04-12-2006 08:29 PM
sbc hole
I have. I don;t remember if sbc. Go to the parts store and compare to others, do you have a fan clutch Is it a big deal- try it or replace it now. I don't remember if you stated what the car is going to be used for. The only idea I can come up with is they didn't want fluid staying between the two bearings. One bearing goes out you get a warning before the fan goes through the radiator- just a thought' I still don't remember where I have seen it , but I have and used it. good luck mark
Jmark 04-12-2006 08:43 PM
There is supposed to be a 1/8" vent hole there. Yours looks like either something rubbed it severly, or someone intentionally ground the nose of the water pump down. Personally, on a new engine, i'd replace it even if it weren't leaking. Its cheap insurance.
madamstn 04-12-2006 09:49 PM
water pump # 2
After blow up- It looks a hammer and chisel hole. Casting looks bent also, the picture looses definition with much blow up. Not a drainor vent hole. Replace it if possible. mark
pcoghlan 04-13-2006 07:46 AM
thanks guys, a replacement is called for me thinks.
