erm, should this hole be here?! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2006, 09:05 PM
Last journal entry: Better late than never
midway through putting my engine (SBC) back together and picked up the waterpump to have it cleaned and painted and came across this hole?!
hmmm...
is it a problem? I didnt have any leaks before it came apart but I have never seen such a hole before?
confused
Paul
ID:	11563   Click image for larger version
Old 04-12-2006, 09:29 PM
sbc hole
I have. I don;t remember if sbc. Go to the parts store and compare to others, do you have a fan clutch Is it a big deal- try it or replace it now. I don't remember if you stated what the car is going to be used for. The only idea I can come up with is they didn't want fluid staying between the two bearings. One bearing goes out you get a warning before the fan goes through the radiator- just a thought' I still don't remember where I have seen it , but I have and used it. good luck mark
Old 04-12-2006, 09:43 PM
Jmark's Avatar
There is supposed to be a 1/8" vent hole there. Yours looks like either something rubbed it severly, or someone intentionally ground the nose of the water pump down. Personally, on a new engine, i'd replace it even if it weren't leaking. Its cheap insurance.
Old 04-12-2006, 10:49 PM
water pump # 2
After blow up- It looks a hammer and chisel hole. Casting looks bent also, the picture looses definition with much blow up. Not a drainor vent hole. Replace it if possible. mark
Old 04-13-2006, 08:46 AM
thanks guys, a replacement is called for me thinks.
400 SBC Steam Hole Crack ezobens Engine 5 03-20-2006 08:28 AM
Drill 1/8 hole in thermostat fat40 Engine 4 02-06-2006 02:53 PM
Hole in back of 231 V6 manifold 78transam Engine 8 12-20-2005 02:03 PM
Cam Bearing Oil Hole DTL504 Engine 2 03-05-2004 11:39 PM
dowel pin hole in crank ? HQ Pete Engine 1 04-28-2002 10:04 AM
