Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Erratic timing in my engine
  #24 (permalink)
Old 06-19-2013, 08:06 AM
eric32 eric32 is offline
Hello since my balancer was new and did not have any groove on the balancer I just used the same crank seal since it was new as well. As far as your balancer puller I don't know how that thing is eating up your threads as mine is similar but cheaper made but it does not go into the crank threads itself just spins at the end of the snout but it never touched any threads and mine was off several times. My piece ended up getting worn out so I had to buy a new one. Mine was brass looking so it had to be somewhat softer then maybe a good quality one. I like the advice on here by using a washer or a nut for it to rid up against and in the future I am going to try it that way in order to protect everything.
