Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Erratic timing in my engine
  #25 (permalink)
Old 06-19-2013, 09:14 AM
eric32 eric32 is offline
Looking at your puller there should be a piece that goes on the end for the puller to pull on and protect your crank snout unless its different then my cheapy one that I got at a autopart store for like 15 bucks. It came with a brass piece that goes on the end of the puller and it is a gold color so it had to be brass as it got worn out after using like 5 times and I had to get a new one. That looks like a solid piece and that would be harder then the one I used and that could eat at the end of the snout but I don't know for sure as I have only used the one I got. I was worried about my threads too and I like the idea of using some washers for future use.
