Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Erratic timing in my engine
  #30 (permalink)
Old 06-19-2013, 09:10 PM
bygddy bygddy is offline
Proud LOSER
Originally Posted by Silver Surfer View Post
I read an article where a dude was having erratic timing. It was caused by either a cheesy nylon thrust button or a worn out aluminum one. As the cam would walk around, the cam gear altered the distributor gear quite a bit.
Actually when I got it all apart tonight I can see what might cause eratic timing, everything was together fine, no unusual wear or extra shiny parts. But that dogbone between the cam and crank, well you could move the crank a full tooth and a bit before it would start to move the cam, the amount of movement was ridiculous. So everything went back together well, didn't use a seal at the bottom of the timing cover, used copious amounts of ultra black lol, made a lovely seal around the outer edge as well, so will see if it leaks tommorow night. Wish me luck. Balancer installer tool should arrive tommorow, will get it buttoned back up tommorow night then saterday will bring it to work, replace all the u-joints to try and cure a shudder on accel. Might throw on a pair of 2 chambers I have to give it some more "presense" lol. Then a big show an hour and a half drive away on Sunday.....that's my story.
