Ertel Camshaft Id ????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2009, 07:01 AM
327 / 350 hp's Avatar
Hi guys & gals, I have traded for a new camshaft for my chevy. its a ERTEL Manufacturing Corp of Can. Part # 115213, It is a GM cam, but i would like to know a little more on its specs. Search refers to ALTA. Any body out there have any dealings,or links.... THANKS jim
Old 02-28-2009, 07:39 AM
Because this is more of a engine question ... than a general tech question, as Moderator I am going to move this to the engine area where hopefully some members with engine experience can answer your question.
Deuce ... Moderator
Old 02-28-2009, 09:00 AM
F-BIRD'88's Avatar
Yada Yada Yada
Ertel (Canada) engine parts (rebuild kits) are out of Toronto.
I believe the company is owned by Hastings.
The cam is in all likelyhood a stock replacement copy as these came in their engine kits. measure the lobe lift by measuring the major and minor diameter of the cam lobe, using a dial caliper or mic. The difference is the lobe lift. X 1.5 is the valve lift.
Most likely .390"intake .410"exhaust valve lift copy of the "929" stock GM V8 cam used in stock base 327's and 350's
If the lift checks out, the .050" duration is 195°-202° 112LSA
If not, then you can likley find the specs by comparing your lift measurments against this listings of various OEM stock, stock performance and popular replacement cams.
http://www.amotion.com/csb.html#20
Comp Cams Xtream Energy 268 camshaft chevymastermind Engine 15 05-22-2007 05:15 PM
Rotella Motor Oil boss350 Engine 14 04-17-2007 11:00 PM
1998 Chevy Venture camshaft kberly54 Engine 2 07-14-2005 08:09 PM
How to choose correct camshaft Drag1racer Engine 0 07-08-2005 04:04 PM
Identification of my Erson mechanical camshaft regens sum Engine 2 06-03-2004 03:23 PM
