ES bushing install? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2013, 07:32 PM
ES bushing install?
Hey guys so I got my control arms back from the powdercoater..I recieved my ES hyperflex kit last week and am about ready to install..I noticed that the guy only melted the bushings out, he did not remove the outside shell..my question was...can I press in the poly bushings or do I have to remove the shell and install the shell they provided with the kit?? If so, how can I get this done without damaging the control arm??
Old 04-21-2013, 08:20 PM
BOBCRMAN@aol.com's Avatar
You will need to remove the shell. This should have been done before powder coat. To remove will require splitting the shell and pressing out.
I do them quite often. A press is required to install.
bushing driver- trans. pump bushing. Chevy350Sb Garage - Tools 2 10-14-2009 09:45 PM
pilot bushing zuker60 Transmission - Rearend 8 09-24-2008 07:15 PM
body bushing install madebadd Body - Exterior 5 05-07-2007 06:56 PM
TH400 bushing coupe66 Transmission - Rearend 2 10-17-2006 07:05 AM
