estimated horsepower - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2012, 07:52 PM
have a 350 bored 30 over i got a set of 327 double hump heads ported and polished from a machine shop here in town now i dont know the flow or any of that the guy i got the stuff from had those done and a 550 lift cam that went with them he never had time to do anything with so i thought 500 hundred for heads and cam wasnt a bad deal . Anyways 350, 327 ported and polished heads 550 lift cam victor jr high rise intake holley 750 carb , mid lenth headers can anyone give me a rough estimate on horsepower havent had it street yet
Old 04-23-2012, 07:45 AM
my87Z's Avatar
Veteran/Firefighter-Paramedic
ditch the vic jr intake go with a performer rpm, is the cam a solid flat tappet or hyd roller. we need more information as well like compression ratio. i also think that a 650cfm carb would be enough since i dont think you are going to make much over 400hp.
Old 04-29-2012, 09:32 PM
its a solid flat tappet and the compression ratio im not for sure on. the heads r 202/160
Old 04-30-2012, 07:23 AM
my87Z's Avatar
i stick with my first guess, maybe around 380hp
Old 04-30-2012, 08:00 PM
my compression is 11 to 1 i talked to the guy i got the set up from i goal is to beat my buddy he has a 85 mustang 306 world product heads 202 160 heads a 544 hydrolic cam summit racing intake and i beleive a 670 carb we dont know what his is pushing either but i would sure like to beat that mustang
Old 04-30-2012, 09:41 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You're going to have your hands full, he has you more than covered, head-wise, and if he has the 18 degree jobs, forget it.
But a LOT has to do w/how well the cars hook up, what vehicle/tranny/gear ratio/rear tires do you have? If you can out 60 foot him, you may stand a fighting chance. May.
Old 05-03-2012, 06:34 PM
how to u figure heads r better basically the same both cast iron flow around same the heads he has ive been told r a waste of money for there price i have a 700r4 with a 3000 stall he has a five speeed have 12 in wide rear tires he has 8 or 9 in cant remember exact
Old 05-04-2012, 10:41 AM
my87Z's Avatar
his world heads are flowing around 230-240cfm@ .500". where the factory double humps only got around 200-205cfm@ .500". i dont know how much work has been done to them but i doubt that they are up to 230-240cfm@ .500", maybe around 215-220cfm. you have to remember that those heads are a mid to late 60's designed head where as his heads were designed in the 90's when information and technology was far better.
and again you need to ditch the single plane intake. if you have any chance at beating him it will be on the low end since you have more cubes you should be able to produce a bit better tq at a lower rpm. you want a simple performer rpm intake, it can take a 350 up to around 6500rpm with no problem. and the victor jr intake will cause your power curve to be extremely sharp, you want it more broad. yes with the performer rpm intake you MAY loose about 10hp, but you will have that extra 10hp (more really) at the lower rpms plus you will likely make around 10-20more tq at the lower rpms.
Old 05-04-2012, 09:35 PM
ok thanks for the info my plans r to make a mean street car and an occasional trip down the strip just for a little fun if i swith the intake do u know a estimated time i might run in a quarter mile
Old 05-05-2012, 12:56 AM
Canzus's Avatar
a red wool sock on his dinger
What car are you trying to make a racecar out of??
Steve & the Rockette...
Too many to list...
Old 05-06-2012, 08:28 PM
its gonna be mainly a street rod but would like to take it down the track once in a while its the 84 camaro
Old 05-07-2012, 09:01 AM
my87Z's Avatar
i run a 87' camaro
it depends on what else has been done to the car, which transmisson are you running. if it is the 700r4 you will want to have it rebuilt since this is a far amount of tq for it to handle. what gears are you running. the 7.5" rear is weak but i think it can handle what you are throwing at it. what size tires. what have you done to the suspension.
if the rest of the car is stock then you wont get much better than a high 13, maybe low 14 in the 1/4. you need shorter gears, shift kit, stall, and some minor suspension work.
Estimated horsepower for this 350 sbc? Hanks56Chevy Engine 4 03-19-2010 04:08 PM
Estimated horsepower for my setup?? brad1 Hotrodding Basics 1 04-07-2009 07:50 PM
Estimated horsepower for my 406 sbc drag S-10 Engine 8 11-15-2005 10:46 PM
estimated 318 horsepower? 67cuda Engine 11 03-11-2003 10:28 PM
Estimated HP PaulyB72 Engine 6 01-31-2002 06:42 PM
