Estimated horsepower - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2013, 10:33 AM
wrm66's Avatar
I just bought a 468 BBC from a guy. I was wordering about how much HP i can expect from it. Here's what i know is in the motor.
.060 over 454 2 bolt block
complete Eagle rotating assmy- Forged crank, forged pistons, rods
10.2 to 1 compression
781 heads- very little port/polish work, basically stock 2.06 / 1.88
292H magnum hyd F/T Comp Cam
750 Deman dbl pumper
Hooker headers
Old 01-15-2013, 11:23 AM
vinniekq2's Avatar
430 or less is my guesstimate. what intake?
Old 01-15-2013, 12:13 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Hooker headers
What intake? Using long tube headers you should be all over 475 crank hp, possibly more. Many engines will make 500 hp using a similar combo but using bigger carb (830 cfm-plus).
The cam is going to bias the powerband upwards. Idle vacuum will be low- too low for power brakes. Idle will be choppy, most guys don't mind that part. Needs more stall speed if AT (around 3500 rpm for street, more for max acceleration/drags). Needs a lot of initial timing as well (18-22 degrees BTDC baseline, adjust from there). Setting up the distributor timing curve is important.
Depending on the rest of the combo (vehicle weight, how it'll be used, rear gear ratio, stall speed if AT just to name a few), the engine may be more drivable/enjoyable using a cam w/less duration and quicker valve action.
Porting the heads and adding 2.19 x 1.88 valves could help, especially if you keep that cam.
To get 10.2:1 CR takes a 20cc-plus dome, even w/a tight quench.
Old 01-15-2013, 01:14 PM
wrm66's Avatar
it has a Torker 2 intake on it now....and i also got a performer RPM air gap that the guy was gonna put on it.
Old 01-15-2013, 01:20 PM
wrm66's Avatar
full length headers
Old 01-15-2013, 01:22 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'm not a fan of the TII (or air gap-type intake), but I do like the RPM-type intakes (Weiand also makes one). Of the two I'd definitely use the RPM AG.
Old 01-15-2013, 01:26 PM
vinniekq2's Avatar
The heads are the weak link in your engine.I used oval ports on my 80 Camaro,modded with 2.19/1.88 valves I took out of my LS-7. with victor oval port intake/830 holley,Z-55 isky solid cam,headers. The car ran a best of 11.93 and weighed 3615 with out driver. NOTE: when I took off the performer and swapped in the victor oval port,it picked up 4/10s.
Old 01-15-2013, 01:48 PM
wrm66's Avatar
The guy told me it should be 425-450 HP at the crank.....so the question is...what wud be the best intake/carb setup to get the max performance out of it....based on leaving the rest of the components alone(heads,cam, pistons, crank, etc)
One guy told me to put a tunnel ram on it, the next guy says a Weiand Stealth ???
Old 01-15-2013, 02:19 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
If you would like advice from a professional who builds these motors for a living, send a PM to Bob. Scroll down on this thread until you see BOBCRMAN@aol.com
Click on his screen name and send him a PM and ask his opinion.
454 performance tweak
Old 01-15-2013, 03:19 PM
wrm66's Avatar
thank you... i'll contact him
Old 01-15-2013, 04:12 PM
The power range will be in the midrange and top end range. A Victor Jr would best suit the camshaft. Like was suggested a 830 or 850 would be a better carburetor to use for max performance.
estimated horsepower cody smithers Hotrodding Basics 11 05-07-2012 09:01 AM
Estimated horsepower for this 350 sbc? Hanks56Chevy Engine 4 03-19-2010 04:08 PM
Estimated horsepower for my setup?? brad1 Hotrodding Basics 2 04-07-2009 11:52 PM
Estimated horsepower for my 406 sbc drag S-10 Engine 8 11-15-2005 10:46 PM
estimated 318 horsepower? 67cuda Engine 11 03-11-2003 10:28 PM
