-   -   Estimated HP (http://www.hotrodders.com/forum/estimated-hp-229489.html)
gvasquez_81 02-13-2013 12:41 AM
Estimated HP
Hey Guys, i have a Chevy 350 from the late 70s early 80s, i was wondering if yo could give me an estiamte on how much hp im running?
442/465 112 lobe sepeartion
64 cc 1.94/1.50 camel hump heads
weiand square bore high rise dual plane intake
edelbrock 600cfm carb
msd dist. with accel wires
flowtech headers no cats with flowmasters
All of this is in a 79 el camino with a 4 speed and i believe stock rear gears
vinniekq2 02-15-2013 07:46 AM
Less than 300.not enough information
snakebit68 02-15-2013 07:52 AM
hp?
Thats not enough information to even attempt a guess. Headers? Stock pistons?
Carb and intake? If I had to guess from the info you provided I'd guess around 250-265. 350 engines from the late 70's earley 80's ran very low compression and came with about 185 hp. An upgraded cam and your heads probably add 50-75 hp.
gvasquez_81 02-15-2013 08:13 AM
I have stock dished pistons. I had smogger heads but put some double humps on there so it might be running 9:5 compression? Just trying to get a general idea
gvasquez_81 02-15-2013 08:15 AM
What information do you guys need and ill tell ya
vinniekq2 02-15-2013 08:30 AM
measured CR with deck height.Air flow of your castings,intake closing time.tuning specs used.
