Estimated HP ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2003, 01:27 PM
OZZ OZZ is offline
Estimated HP ??
I found a 454 with this equipment in it and was wondering how much estimated HP and TQ you guys would guess it to produce ??
Also Ill be using it for a 4 x4 that will be driven regularly (not daily but close) but I love power at the same time, wondering if this might be a bit hot for my needs as I am concerned about reliability ?
Thanks !!
EQUIPMENT:
454 big block chevy. The block is a 454 bbc 2 bolt main, 2pc rear main block. Block has been checked for cracks and cleaned inside and out.GM oval port heads. Engine is at about 9.7:1 compression with 116cc heads so its pump gas useable. Has a Edlebrock Performer plus fuel pump. (New Parts):-- Speed Pro TRW-L2465 forged pistons,freshly resized and studed rods, Speed Pro chrome moly rings,Edlebrock Performer RPM camshaft (Dur.@.50" 240I/246E,Gross valve lift.560"I/.573"E,LobeSeperation:112,Edlebrock Performer RPM lifters, Clevite 77 rods and mains,Dynagear High Volume oil pump, Felpro gaskets,comp cams magnum roller rockers, GM valve locks & retainers,valve guides,pioneer brass freeze plugs,Hardend pushrods,guide plates,Edlebrock Performer rpm valve springs, Cloyes Heavy duty double row 3 key timing chain, Fresh grind crank, sfi approved balancer,High Performance water pump, Edlebrock Performer Rpm high rise intake, Edlebrock deep style chrome valve covers,Edlebrock 14" chrome breather, chrome thermostat housing,Custom Stock Pro Spark plug wires, Ac Delco spark plugs, Hei distributor with new Power Coil kit installed, Headman Headers.... Machine Work (block):cleaned inside and out. COMPLETLY BALANCED,checked for cracks,necessary bore, and honed. Freshly ground crank and resized connecting rods and studed
Old 09-26-2003, 06:29 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
What type heads and size valves are on it? HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 09-26-2003, 09:00 PM
WV hillbilly
Last journal entry: PTL 220CC
Id say 440hp/460ftlbs
