-   -   Estimated HP and Torque sbc 355, please (http://www.hotrodders.com/forum/estimated-hp-torque-sbc-355-please-203415.html)
AR_Racing_627 08-08-2011 11:20 PM
Hello, big fan of the site and its educated users. I am wondering if someone would like to run my setup on an engine calculator in order for me to select a few more parts for my car. If so I will post the details of the engine and drive terrain, if not then i wont, lol, i will check back shortly for replies, again thank you.
eloc431962 08-09-2011 06:15 PM
If you want someone to do it you might as well go ahead and post all the parts involved. JMO
Cole
valtiel43 08-09-2011 07:22 PM
I got desktop dyno on my pc so if you post all the specs I can put it in.
AR_Racing_627 08-10-2011 12:23 AM
Thank you 43.
355
stock bottom end
balanced hyper pistons with 4 valve reliefs
roller timing set
213 int./219 exh.at .050 (voodoo 60101)
*0.454 int./0.468 exh. with my 1.5 rockers
stock vortec heads 1.94/1.50 (Felpro head gaskets)
edelbrock rpm air gap dual plane
600 edelbrock
new HEI ignition
1 1/2 long tube headers
400 turbo stock
3.08 gears
225/75/14 tires
4,300 lb 77 Monte Carlo
Again Thank You, valtiel43
I know in 2nd gear it will turn around 6,100 rpm. its a dirt car...
cool rockin daddy 08-10-2011 07:03 AM
That's gonna be about 375-380 HP with around 400 lb ft TQ.
valtiel43 08-10-2011 10:16 AM
Originally Posted by AR_Racing_627
Thank you 43.
355
stock bottom end
roller timing set
600 edelbrock
new HEI ignition
400 turbo stock
3.08 gears
225/75/14 tires
No problem.
It has it at peak hp 389 @ 5500rpms, and torque 409 @ 4000 rpms.
AR_Racing_627 08-10-2011 06:02 PM
alright thanks, i know it pulls pretty good but was unsure of what i really had, i was thinking about going with a little more cam and 2500 stall converter
cool rockin daddy 08-10-2011 09:20 PM
Dang, I didn't even have a dyno sim when I made my post.
AR_Racing_627 08-14-2011 01:44 PM
well u were pretty darn accurate lol
Valkyrie5.7 08-14-2011 03:38 PM
Right now I'd do something about that rear end ratio before I stepped up to more stall and cam. 3.55 or 3.73s would make it pull like a freight train in comparison. You're going to need more gear if you want to step up the cam and stall anyways, especially in a big heavy monte carlo.
Btw, nice guess CRD. :thumbup:
FmrStrtracer 08-14-2011 03:44 PM
If its a dirt car, isnt it stripped down? 4300lbs seems heavy if its stripped.
AR_Racing_627 08-15-2011 06:05 PM
its a figure 8 car so i have lots of steal welded in it including a 12" by 5 1/2' I beam for a rear bumper, so she weighs in.
I'm running the 3.08 gears for lower rpm's i had the 3.73's in it and she wrapped out way to quick.
