Estimated HP and Torque sbc 355, please - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2011, 10:20 PM
Hello, big fan of the site and its educated users. I am wondering if someone would like to run my setup on an engine calculator in order for me to select a few more parts for my car. If so I will post the details of the engine and drive terrain, if not then i wont, lol, i will check back shortly for replies, again thank you.
Old 08-09-2011, 05:15 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
If you want someone to do it you might as well go ahead and post all the parts involved. JMO
Cole
Old 08-09-2011, 06:22 PM
valtiel43's Avatar
I got desktop dyno on my pc so if you post all the specs I can put it in.
Old 08-09-2011, 11:23 PM
Thank you 43.
355
stock bottom end
balanced hyper pistons with 4 valve reliefs
roller timing set
213 int./219 exh.at .050 (voodoo 60101)
*0.454 int./0.468 exh. with my 1.5 rockers
stock vortec heads 1.94/1.50 (Felpro head gaskets)
edelbrock rpm air gap dual plane
600 edelbrock
new HEI ignition
1 1/2 long tube headers
400 turbo stock
3.08 gears
225/75/14 tires
4,300 lb 77 Monte Carlo
Again Thank You, valtiel43
I know in 2nd gear it will turn around 6,100 rpm. its a dirt car...
Old 08-10-2011, 06:03 AM
cool rockin daddy's Avatar
That's gonna be about 375-380 HP with around 400 lb ft TQ.
Old 08-10-2011, 09:16 AM
valtiel43's Avatar
Originally Posted by AR_Racing_627
Thank you 43.
355
stock bottom end
roller timing set
600 edelbrock
new HEI ignition
400 turbo stock
3.08 gears
225/75/14 tires
No problem.
It has it at peak hp 389 @ 5500rpms, and torque 409 @ 4000 rpms.
Old 08-10-2011, 05:02 PM
alright thanks, i know it pulls pretty good but was unsure of what i really had, i was thinking about going with a little more cam and 2500 stall converter
Old 08-10-2011, 08:20 PM
Dang, I didn't even have a dyno sim when I made my post.
Old 08-14-2011, 12:44 PM
well u were pretty darn accurate lol
Old 08-14-2011, 02:38 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
Right now I'd do something about that rear end ratio before I stepped up to more stall and cam. 3.55 or 3.73s would make it pull like a freight train in comparison. You're going to need more gear if you want to step up the cam and stall anyways, especially in a big heavy monte carlo.
Btw, nice guess CRD.
Old 08-14-2011, 02:44 PM
If its a dirt car, isnt it stripped down? 4300lbs seems heavy if its stripped.
Old 08-15-2011, 05:05 PM
its a figure 8 car so i have lots of steal welded in it including a 12" by 5 1/2' I beam for a rear bumper, so she weighs in.
I'm running the 3.08 gears for lower rpm's i had the 3.73's in it and she wrapped out way to quick.
Sbc 327 (Estimated HP) PaulsChevy64SWB Hotrodding Basics 19 02-23-2011 04:32 PM
Estimated Torque And Hp For A 454, Here's The Build Specs adantessr Engine 6 01-19-2011 03:08 PM
355 estimated HP and TQ Cunferferth Engine 85 05-06-2010 08:25 PM
454 cam?,and estimated hp dboyett38606 Engine 3 01-27-2007 09:47 PM
Estimated HP ?? OZZ Engine 2 09-26-2003 08:00 PM
