Estimated time and mph - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2012, 08:34 PM
I have a 67 Camaro with a 491 motor. The motor has an Eagle 4.250 rotating assembly with forged crank with Icon .040 forged pistons. It has 10.2 compression ratio with 118 cc heads. The chevy block has been decked with the pistons .005 down in the hole. The quench is at .041. Also has been internally balanced. The camshaft is a Crower mechanical roller #01485. Lobe lift at .050 is intake .377, exhaust .374 and duration is intake .256 and exhaust 266. lobe separation is 107 and intake center line is 103. The heads are Edelbrock Performer 454 Rectangle Port with the valve springs changed for the Crower cam. Intake is the Victor Jr with a Holley 850. The main body has been replaced with a Proform main body and billet throttle base plate. It has a TH400 and stall converter from JP Performance built for the engine specs,car,rear 12 bolt 4.11 and 27" tires. It has Caltracs on the rear suspension. Front suspension has Global West upper and lower tubular control arms with coil-overs. When I get a chance to take it to the track what times and mph should I expect it to run if it hooks.
Old 07-25-2012, 08:45 AM
my87Z's Avatar
Veteran/Firefighter-Paramedic
based on what you posted, i would guess that the engine is pushing in the area of 600hp/600tq (give or take a bit), that in front of a 3100-3300lbs car should have you running 10.80-11.20's at roughly 118-124mph in the 1/4, supposing that everything is in tune right and you can get it to hook up.
just my estimate
for the cam, the compression seems to be alittle on the light side, if it where in the 11.0:1-11.5:1 range i would probably say you would be looking a bit closer to mid 10's
Old 07-25-2012, 08:55 AM
The compression could be a little higher, not much with the decking. Usually you can get away with 1/2 point either way with the camshaft. With this cam and the exhaust overlap it should run on 93 octane gas. Just wanted an idea of what time and mph would be good for this motor. Something to work at. Thanks for the reply.
Old 07-25-2012, 09:00 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Unless someone volunteers to run the specs on their software, you can use Comp's CamQuest program. Using your engine specs, see if the software shows a cam w/specs close to yours to get a HP/TQ estimate.
Using the estimate and any number of online calculators (here are a few), you can extrapolate estimated 1/8 and 1/4 mile ET/MPH, along w/other estimates like 60', etc.
Sounds like a strong combo, in any event. Good luck w/it.
Old 07-25-2012, 09:39 AM
Thanks Cobalt327 for the tip on the online calculators. I have been to Comps website before. The CamQuest program will only let me enter info on the stock 4 inch stroke. I have been told that the hp and torque is above 600 with this setup. This is fine with me.
Old 07-25-2012, 10:21 AM
my87Z's Avatar
it probably is but i typically try to be conservitive. with your compression though i dont think you are above 650/650. with the cam that you have and the alm heads you could have likely gotten away with around low 11's:1 on 93 pump gas and would have upwards of about 5-10% more hp, that might not sound like much but based on 600hp, that 30-60hp more.
the decking doesn't really play a huge factor in compression ratio since you still have to have the quench area at an acceptable level.
wither way it sounds like a good street/strip motor and should get you in the high 10's as long as you can get it to hook, with the lighter wieght of the car you could even see the high side of the mid 10's.
bbc, camaro
estimated new compression? ForceFed86 Engine 6 12-14-2009 12:36 PM
estimated 1/4 mile time?? tirefryin_s10 Hotrodding Basics 7 10-20-2006 01:54 PM
Front Seal on 300Z, estimated time? Dizturbed One Transmission - Rearend 5 11-16-2005 05:58 PM
Estimated HP ?? OZZ Engine 2 09-26-2003 09:00 PM
Estimated HP PaulyB72 Engine 6 01-31-2002 07:42 PM
