Etch-o-matic???
Hey guys, I was looking for a cheap way to etch metal. Just for some small projects. It doesn't have to be high quality like laser, just something that will last ok in normal conditions.
I came across this: www.etch-o-matic.com My question is have any of you seen, used or heard of this. If so, does it really work that well or is it one of those to good/cheap to be true deals. The starter kit is probably all I need. So if I can do over 1000 etchings with this for less than $100 it has my attention, plus you can get a glass etching kit for another $25 to add onto it. What do you guys think? Thanks for the input |
Sounds to me like the acid etching we did in high school chemistry with a little hype added.I don't know what you're planning on etching, but simple etches can be done with a little battery acid and some wax for a stencil. Example: marking a wrench- clean completly with a solvent that doesn't leave a residue such as electrical contact cleaner. Dip in melted wax just enough to leave a thin coat. Cut out the design you want in the wax, drip on a little acid, wait a bit, wash off, inspect and if it isn't enough add a little more acid and repeat. The quality of the etch depends on your skills as an artist.
IMHO Timewise this would eat you up. It took a minute to fake do one card from start to finish. Including equipment, materials and some for your time your first 60 cards are going to cost $240.00 and at best they are going to get to about .80 each. This estimate didn't include any prep time.
I am loking for a cheap alternative to laser etching. This looks to be it, I just wanted to know if it actually worked or not.
I don't intend to just use it for the cards. I don't need them that bad, but it would be nice for other things, especially some custom looking accent pieces for future hot rods. I am not sure if I will do it or not. Just thought i would see if anyone has used it and if they reccomend it or not. |
We used to use something very similiar at work to etch tooling (hardened tool steel) That was before the computer age. It had a special paper and you did it with a typewriter and some type of acid. Not exactly sure of the process now. But we have tools around yet that still have the markings on them, and that has been 25 years ago that I did it. For the money, I don't think it sounds like a bad deal. But that is my $.02 worth, and $.02 doesn't go very far anymore.
Kevin |
| Recent Garage - Tools posts with photos |
| etch primer question | beemdubya | Body - Exterior | 10 | 10-30-2005 07:47 PM |
| PPG Omni self-etch - what is it SUPPOSED to look like? | Fat_46 | Body - Exterior | 14 | 09-30-2005 09:10 AM |
| To etch or not to etch | chevy4llife88 | Body - Exterior | 5 | 01-02-2005 07:09 PM |
| Proper uses for acid etch primer? | Rocket1 | Body - Exterior | 7 | 09-09-2004 07:50 PM |
| to etch or not to etch? | Cowtown Punk | Body - Exterior | 8 | 01-13-2004 05:41 PM |
